Qcad will not allow drawing units to change in drawing preferences
lesthegringo
Post by lesthegringo » Sat Feb 02, 2019 12:18 pm
Guys, running Windows 10, Qcad Version 3.21.3.0 (3.21.3)
I am trying to design something that requires me to use both metric and imperial measurements, metric being the main unit for overall dimensions, but then a subset of the part has to be measured in imperial units in order to fit in with circuitry on PCB's that are measured in imperial units.
As a result, I have set up the Application preferences to Metric, millimetres, 5mm grid spacing. I can then draw the major dimensions and overall sizes to fit my needs, but then I want to change to imperial units (inch, 0.05" grid) so that I can put in the electronics parts. Following the instructions I go to drawing preferences, change to inches, set the grid, click apply..... and nothing happens. The units stay in millimetres, the grid as 5mm spacing, and when I look at line properties, it quotes the length in millimetres.
I've tried saving and restarting Qcad, then reopening the file, all to no avail. Am I missing a step somewhere?
Cheers
Les
Re: Qcad will not allow drawing units to change in drawing preferences
Post by Husky » Sat Feb 02, 2019 8:44 pm
you need to convert the drawing unit. The tool can be found below Menu/Edit/Convert Drawing Unit.
Note: Changing the Unit below Drawing Preferences will change e.g. a 100 mm line to a 100 inch line.
lesthegringo
Post by lesthegringo » Sun Feb 03, 2019 8:38 am
Fantastic, many thanks for that!
Les
