dwg2maptiles - space around image
simtaylo
Post by simtaylo » Wed Jan 16, 2019 2:36 pm
When I use the dwg2maptiles it generates a lot of white space around the drawing. If I save the same file to a image from QCAD the image is nicely set to the extents of the drawing. How can we do the same with dwg2maptiles so the 256 x 256 image is filled with the drawing ?
Attached a sample .bmp saved from QCAD and the 0 resolution image from dwg2maptiles
Re: dwg2maptiles - space around image
Post by andrew » Wed Jan 16, 2019 3:29 pm
The 0 tile should indeed be centered and fill the whole tile. Can you attach, PM or mail your DXF or DWG please, thanks.
- indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD or indicate the name of the file you have downloaded and installed)
simtaylo
Post by simtaylo » Wed Jan 16, 2019 4:02 pm
Attached the 2 DWG files.
I am on MAC 10.14.2
Version:
3.21.3.0 (3.21.3)
Internet:
QCAD.org
Build Date:
Sep 17 2018
Revision:
4b91c8c
Qt Version:
5.10.0
Architecture:
x86_64
Compiler:
Clang 8.0.0
SNG15_24.dwg
(2.1 MiB) Downloaded 44 times
SJCI_1.dwg
(428.35 KiB) Downloaded 42 times
Post by andrew » Wed Jan 16, 2019 5:14 pm
Thanks. There are some (empty) block references in the seemingly empty space of the drawing:
Schermafbeelding 2019-01-16 om 16.11.59.png (140.36 KiB) Viewed 968 times
These will be ignored in a future version. For now, please delete those block references (rectangle select and delete).
simtaylo
Post by simtaylo » Thu Jan 17, 2019 12:49 pm
I have turned on all the layers and I still cannot see these things to select them and delete ?
What about the other file, does that have the same problem ?
Many thanks for the help
Post by andrew » Thu Jan 17, 2019 3:33 pm
These blocks are empty (i.e. there is nothing to display). You can find them by zooming out and selecting all (Select > Select all). They will then show up as blue reference points.
I also checked the other drawing, however, that case is a bit different. There appear to be block references with reference points far away from the drawing contents. Unfortunately, there is no easy workaround for such a file (short of exploding all block references). You'd have to wait for the next release for a fix.
