QCAD Merge tool output to RDCAM
quentin
Post by quentin » Thu Dec 20, 2018 10:42 pm
Hi there,
i'm using the QCAD merge tool to merge some DXF and after that I try to open it on the RDCAM Software to make it cutted.
I'm facing a problem : only one block (called cadre) is showing on RDCAM. So I can't cut it directly. On other CAD tools, all blocks are visible (QCAD, LibreCad etc)
To avoid the problem, I have to open my QCAD generated DXF on AI, then I export it again to a DXF file so RDCAM can read it.
I wan't to resolve this issue for not using adobe anymore
It's quite weird, and I don't know if it's a QCAD problem or not.
I'm using qcad-3.21.3-pro-linux-x86_64 on Ubuntu 14.04 X64
Attached, and example of the DXF output of merge QCAD command.
And a screenshot of RDCAM V8 showing only one block.
If someone have an idea about it ...
Thank's,
Quentin
20181220_Planche_1.dxf
(239.68 KiB) Downloaded 46 times
Re: QCAD Merge tool output to RDCAM
Post by Husky » Thu Dec 20, 2018 11:47 pm
not sure but please try this in QCAD modified drawing in your CAM software.
20181220_Planche_1_mod.dxf
(266.03 KiB) Downloaded 54 times
If that works I tell you what I did with the drawing. :wink:
quentin
Post by quentin » Fri Dec 21, 2018 9:02 am
Thank's for you answer,
I can confirm : It works :)
So, how to ? :)
Quentin
Post by Husky » Sat Dec 22, 2018 12:14 am
Great!
It looks like your CAM is not able to handle nested blocks (block which are built with other blocks). The block cadre isn't nested - it's a plain block and that is why it was shown in your CAM.
For the next drawing I would recommend not to nest blocks.
How I fixed it: I selected everything in the drawing and used the explode tool. Saved it for you and you already know the end of the story :lol:
quentin
Post by quentin » Sat Dec 22, 2018 10:17 am
Hi Husky,
Do you know if there is a way to batch script this "explode" function on all nested blocks with a command line operation ?
Quentin
Post by Husky » Sun Dec 23, 2018 6:13 am
Sorry, I can't help you with that question ... :oops:
