Linearfaktor - linear factor
Mapoli
Post by Mapoli » Fri Nov 23, 2018 8:32 pm
My linear factor is 2 for the dimension, How can I reset the linear factor to 1?
Re: Linearfaktor - linear factor
Post by Husky » Fri Nov 23, 2018 9:11 pm
To edit an already existing linear factor you can use the Property Editor.
To control the linear factor during creating a dimension keep an eye on the option bar.
The option bar will remember the last used value!
