When using the Distance Point to Point IP command, QCAD pro has started to leave a line with tickmarks every 1mm (= grid) plus the distance in text on the current layer permamnently on the drawing. Can only be removed practically with the Undo command, as the line, each tick mark, and text are all separate entities. Is this a bug or have I accidentally turned on an option?. I would very much like to turn it off again!. Cannot find anything in the ref manual. Thanks.
Windows 7 64bit
Version:
3.21.3.0 (3.21.3)
Internet:
QCAD.org
Build Date:
Sep 17 2018
Revision:
4b91c8c
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
MSVC++ 12.0 (2013)
IP leaves ticked line and dimension
- IP-ticked-line.png (32.41 KiB) Viewed 3420 times
Re: IP leaves ticked line and dimension
That's got it, many thanks. That must be the tenth time I've forgotten to look there. I spent 30 minutes wondering how to set the distance for an Offset command!
