Splines
- Newbie Member
Splines
I have created a DXF file which contains a top view of a ship.
I can open the file in 3.4.5.0 without any problems.
In version 3.21.3.0 the splines are corrupt.
If I save the file in Version 3.4.5.0 in DXF R24 or R27, the problem is the same.
Does anyone has an idea why it happen?
Kind regards
Matthias
Re: Splines
Looks like the spline start / end tangents are not correct.
Try this:
1. Select > Select all
2. Misc > Modify > Reset Spline Tangents
If you can't solve it, attach the file please.
Try this:
- Newbie Member
Re: Splines
Hello Andrew,
Thank you. It works.
Kind regards
Matthias
Kind regards
Matthias
Re: Splines
I hit the same problem going from 3.15.5 to 3.22.0. The same correction worked for me.
Attached is the dxf before the correction in case that is useful to see where the odd tangents originated. I don't recall having selected tangents in the first place, and the property editor does not allow turning off using tangents.
- wheelwriter.dxf
- (1.63 MiB) Downloaded 85 times
