Small bug in the tool settings
Rantanplan7
Senior Member
Post by Rantanplan7 » Thu Aug 16, 2018 2:11 pm
Hi there,
not something serious but a quite strange behaviour.
If I untick in the general tool settings the delete function from the tool bar, than I can't delete somthing by pressing the delete button on the keyboard anymore, the ER shortcut still works. If I put a tick in the checkbox for the delete function at the tool bar again, the delete button on the keyboard works.
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Re: Small bug in the tool settings
Post by andrew » Fri Aug 17, 2018 4:38 pm
Thanks for the report. Unfortunately, I'm unable to reproduce this here.
