Info - Polyline Area (dont measure)
gastonbravo
Post by gastonbravo » Mon Aug 06, 2018 3:28 pm
Hi!
Im using qcad 3.21.2
Im trying to calculate polyline area (previous version work),
but dont show.
Info - Polygonal Area works but i have to "redraw" the polyline
http://prntscr.com/kfc3w2
Thanks for your work!
Re: Info - Polyline Area (dont measure)
Post by Husky » Mon Aug 06, 2018 8:14 pm
please attach an example drawing which shows this effect. Thanks.
BTW: The Property Manager will give you also that information.
gastonbravo
Post by gastonbravo » Mon Sep 24, 2018 11:23 pm
Thanks Husky , but, property editor dont give me area also.
Now using 3.21.3 version
https://prnt.sc/kya075
Post by Husky » Tue Sep 25, 2018 1:22 am
Please attach the drawing (or just an example) which shows this issue. Thanks.
gastonbravo
Post by gastonbravo » Thu Mar 21, 2019 8:08 pm
hi, im cant measure area, from info - polyline or property editor.
send 2 images and a drawing file example,
property editor show : Closed : "no". (but seems closed)
In others pc,s this example works (give area), so it's a problem with mi installation
(remove, clean registry, remove all qcad's file, reinstall many times).
Any help
https://drive.google.com/open?id=1HacTg ... uWdGrGjdwd
https://drive.google.com/open?id=1C6wBj ... I0tAupqpYh
https://drive.google.com/open?id=1dwi4a ... 7Qei3CG3LL
qcad ver: 64bits 3.22.0
OS: Windows 10 64 b.
default installation procedure
Thanks!
Gaston
J-J
Post by J-J » Thu Mar 21, 2019 9:07 pm
Hi gastonbravo,
weird, after loading your dxf, I get 170 units, both in the property editor and with polygonal area. Running latest QCAD on win 7-64
JJ Win7 pro-64
gastonbravo
Post by gastonbravo » Thu Mar 21, 2019 9:40 pm
Hi J-J, thanks, that's right, in other pc s works fine
(and in my notebook, works 6 month before) i used a lot.
So it's an issue in my particular installation (no general problem).
Thanks anyway
Saludos desde Chile
Gaston
Post by andrew » Thu Mar 21, 2019 10:46 pm
I'd recommend to try resetting your QCAD configuration. Optionally, you might want to backup your old QCAD3.ini file first and then post it here if that turns out to be the problem, so we can look into what caused the problem.
