Dear all,
I used Ctrl+W shortcut to close QCAD tab. Since last version installation 3.21.2.0 (3.21.2), it's not working anymore. I cannot see in in the window top menu neither.
I'm running QCAD Professional 3.21.2.0 (3.21.2) in Linux Ubuntu 18.04 LTS.
Ctrl+W not closing QCAD tab
Re: Ctrl+W not closing QCAD tab
Could it be that you've (accidentally) installed the legacy package for older Linux distributions which uses Qt 4?
For Ubuntu 18, you should be able to use the regular Linux package instead.
- dfriasb
- Senior Member
That's it!! Thanks a lot Andrew!
