Issue when using Library Browser to insert a logo.
cody
Post by cody » Wed Jul 11, 2018 10:59 pm
Operating System:
Windows 10
QCAD Info:
Version: 3.21.2.0 (3.21.2)
Internet: QCAD.org
Build Date: Jul 9 2018
Revision: f7fc4f9
Qt Version: 5.5.1
Architecture: x86_64
Compiler: MSVC++ 12.0 (2013)
Images:
logoWhenUsingLibraryBrowserToInsert.svg
Hatching on the S and P did not work properly
(45.82 KiB) Downloaded 380 times
logoWhenUsingImport.svg
Hatching worked fine
(50.08 KiB) Downloaded 362 times
Issue:
When I use the Library Browser to insert the "skiplineLogo.dxf", I get an issue shown in the attached image (logoWhenUsingLibraryBrowserToInsert.svg). If you look closely, you will notice the "S" and "P" are not completely filled in.
When I use the Import function to insert the "skiplineLogo.dxf", it works just fine, shown in the attached image (logoWhenUsingImort.svg).
I am not sure if this is a bug or if it is an issue with the skiplineLogo.dxf? Please let me know if you have any tips.
Thanks!
cpr-1112.dxf
file i am inserting to logo into
(237.62 KiB) Downloaded 272 times
skiplineLogo.dxf
the logo I am trying to insert
(160.2 KiB) Downloaded 293 times
Re: Issue when using Library Browser to insert a logo.
Post by andrew » Wed Jul 11, 2018 11:12 pm
Are you reporting an issue with the SVG export or does the problem also show on your screen in QCAD? Thanks.
cody
Post by cody » Wed Jul 11, 2018 11:19 pm
On the SVG Export.
