What does "View->Display Distance/Angle" do?
Jef
Post by Jef » Sat Jul 07, 2018 9:04 pm
The title says it all. I'm wondering what this feature is supposed to do. Nothing happens when I select it, and the Reference Manual is no help at all.
QCAD version: 3.21.0.0
openSUSE Linux
Re: What does "View->Display Distance/Angle" do?
Post by Husky » Sun Jul 08, 2018 4:16 am
Category and tool name says it all. :wink: It displays the distance and the angle at the mouse pointer.
Nothing happens when I select it ...
If there is no distance and/or angle which can be displayed then nothing will happens.
Try this:
Activate the Display Distance/Angle,
Launch the "Line from two points",
determine the first point and monitor what happens at your mouse-pointer for the second point ...
... and the Reference Manual is no help at all.
Well - I think text and symbols will give you all hints what you need ... :wink:
Jef
Post by Jef » Mon Jul 09, 2018 10:51 pm
Try this:
Thanks for your help. I finally figured it out after much trying. It's a toggle, between several types of info displayed while drawing. The fact that the status of the icon in the menu never changes doesn't help.
A couple of words to that effect in the Manual would help, since this tool behaves differently from most (or even all) other tools.
