[solved] Dimensions do not match Line size
Dimensions do not match line length
- Capture.JPG (25.57 KiB) Viewed 5421 times
Re: Dimensions do not match Line size
Most likely the linear factor of your dimension entity is not 1 (see property editor).
If that does not solve your problem, please attach your DXF file.
Problem solved Thanks
Re: [solved] Dimensions do not match Line size
is there a default linear factor i have to change each dimension to 1
- Drawing.dxf
- (99.99 KiB) Downloaded 481 times
For existing dimensions:
- select all dimensions
- use property editor to change linear factor to 1
For new dimensions:
- while drawing a dimension, you can enter the linear factor in the options toolbar at the top
For new dimensions:
