Can't Explode Block
MikeMillerPE
Can't Explode Block
Post by MikeMillerPE » Sat Jun 09, 2018 8:16 pm
OS: Windows 10 Pro 1803, 64-bit, 8G RAM, 10 cores
QCAD Ver. 3.20.1
I imported an AutoCAD dwf using QCAD, and couldn't explode the block, so I saved it as a dwg and tried again. No luck.
Any ideas?
PS: I tried to upload the dwf also, but the system would'nt let that filetype in. The file (1611000A.dwf) is available at
http://www.landxml.org/webapps/landxmlsamples.aspx
1611000A.dwg
(156.48 KiB) Downloaded 419 times
Mike Miller, P.E.
Re: Can't Explode Block
Post by Husky » Sat Jun 09, 2018 8:27 pm
I have no problems to explode the block. I'm on Win10 too. dwg / dwf works just fine ...
MikeMillerPE
Post by MikeMillerPE » Fri Jun 15, 2018 8:39 pm
Husky,
It seems that some of the ECMA scripts was causing my issue. Thanks for helping me troubleshoot the problem!
Mike
Mike Miller, P.E.
