Artifact when I copy and paste
Robert36
Post by Robert36 » Fri Mar 23, 2018 7:13 pm
I have the latest Pro Version of QCAD and am running a PC.
I am copying and pasting exploded entities. I used the spline tool initially. I notice when I use the selection tool, there are lots of associated "artifacts" for lack of a better word. What is the function? Second question...... does uninstalling QCAD Pro in order to upgrade to the CAD?CAM version..... does it put any kind of work I've done to date in jeopardy of being lost or misplaced? My assumption is it's fine.
I wanted to post a screen shot but was unable to post a screen shot. Control V didn't work. Obviously I am a bit of a luddite when it comes to 'puters.
Re: Artifact when I copy and paste
Post by Husky » Fri Mar 23, 2018 7:41 pm
Robert36 wrote:I am copying and pasting exploded entities. I used the spline tool initially. I notice when I use the selection tool, there are lots of associated "artifacts" for lack of a better word. What is the function?
Without a screenshot or example drawing its a kind of guessing - let see ...
Does it look like this?
If yes then this "artifacts" are the center point of each arc. Most likely your exploding led to a shape just built out of a lot of arcs.
Robert36 wrote:Second question...... does uninstalling QCAD Pro in order to upgrade to the CAD?CAM version..... does it put any kind of work I've done to date in jeopardy of being lost or misplaced? My assumption is it's fine.
I would recommend to keep the "old installation until you are sure the new installation is proper working! To do so don't use the .msi installation packet for windows - it will automatically de-install the old version of QCAD. Use the zip archive instead - decompress it in a new/empty subdirectory and create a shortcut to qcad.exe.
Now you are able to run both installation independently (but not at the same time!) and when you sure you don't need anymore the old installation just delete it.
Robert36
Post by Robert36 » Sat Mar 24, 2018 6:12 am
Good guess Husky and thank you.
