[solved] Dimensions off scale
Jan-Ola
Post by Jan-Ola » Thu Mar 08, 2018 9:27 pm
I have just bought QCAD pro, so I am a bit new to this. Drawing the geometry works fine, but the dimensions have started to show a factor five too large numbers. It is like I am drawing at scale 1:5, but I cannot find that I have a setting like that. I get this even if I restart QCAD and make a new drawing from scratch.
In paper space there is a scale setting in the toolbar, but it is set to 1:1 and Edit -> Drawing Preferences -> Dimension settings -> size scale factor is set to 1. Is there another scale somewhere?
Jan-Ola
Re: Dimensions off scale
Post by andrew » Thu Mar 08, 2018 9:37 pm
Please refer to this topic which very likely covers the problem you are having:
viewtopic.php?f=33&t=5052
Jan-Ola
Post by Jan-Ola » Fri Mar 09, 2018 1:18 pm
Yes - there it was! I had missed that scale setting.
Thanks a lot!
/Jan-Ola
