[solved] Print Preview views are reversed
Posted: Sat Dec 23, 2017 7:23 am
by slyde
I haven't checked this on Windows, but when i go to Print Preview the landscape and portrait seem to be reversed.
- Screenshot from 2017-12-23 00-11-06.png (267.45 KiB) Viewed 5996 times
- Screenshot from 2017-12-23 00-11-16.png (274.69 KiB) Viewed 5996 times
Re: Print Preview views are reversed
Posted: Sat Dec 23, 2017 7:58 am
by Husky
slyde wrote:... the landscape and portrait seem to be reversed.
You're using a custom Paper size? Maybe Paper width and height is mixed up. If not launch the Print Preview tool, Option Bar / Drawing Preferences / Page and switch from Portrait to Landscape or the other way around.
Posted: Sat Dec 23, 2017 8:35 am
by slyde
I see what you're saying, Husky. I had the Page setup all wrong. Sorry.
Posted: Thu Dec 28, 2017 9:25 am
by Matfie
Hi
I reported this in the bugtracker before:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1518
I agree that technically the program may be acting logically... but the UI is not technical it is for people. Landscape means that the page you see is wider than it is high, not that the attribute labelled height is laid horizontally
