[solved] Copy/Paste off 180 degrees
slyde
Post by slyde » Sat Dec 16, 2017 1:26 am
Hi Forum:
I hope this is just a setting that I can change, but all of my pastes are off 180 degrees. Look at the pics.
This is what I copied.
Screenshot from 2017-12-15 18-19-37.png (41.18 KiB) Viewed 2278 times
And here it is on the clipboard.
Screenshot from 2017-12-15 18-20-40.png (3.96 KiB) Viewed 2278 times
And this is what I get when I paste it.
Screenshot from 2017-12-15 18-22-06.png (32.3 KiB) Viewed 2278 times
Can anyone tell me why this is happening and what I can do to fix it? Thanks.
Slyde
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Copy/Paste off 180 degrees
Post by Husky » Sat Dec 16, 2017 3:55 am
Hi Slyde,
slyde wrote:Can anyone tell me why this is happening and what I can do to fix it?
please check in the Paste / Option bar the switches for flipping entities ...
slyde
Post by slyde » Sat Dec 16, 2017 4:20 am
Thanks for responding, Husky.
I can't find that option.
Screenshot from 2017-12-15 21-16-31.png (186.51 KiB) Viewed 2273 times
I've opened every toolbar, went through all of the menu. Where is this option found? :-)
Slyde
Post by Husky » Sat Dec 16, 2017 4:28 am
We're talking about the Clipboard / Paste function?
Launch the Paste Tool and the Option Bar pops up ...
... if not then it is deactivated. Please check:
slyde
Post by slyde » Sat Dec 16, 2017 4:40 am
I can't take a screenshot with a menu rolled out, but I have Options checked. And when I toggle it on/off, this tool icon appears and disappears. But it isn't what you have.
Screenshot from 2017-12-15 21-38-41.png (995 Bytes) Viewed 2271 times
Slyde
Post by Husky » Sat Dec 16, 2017 4:49 am
slyde wrote:But it isn't what you have.
What happens with this icon when you launch the Paste tool? It should change ...
slyde
Post by slyde » Sat Dec 16, 2017 4:53 am
Fixed.
None of that shows up until you ctrl + V
I got it cleared up. Thank you. And I apologize for my slowness. It never occurred to me that this tool wld show up on Paste only. My bad.
Slyde
Post by Husky » Sat Dec 16, 2017 6:59 am
You are welcome.
slyde wrote:It never occurred to me that this tool wld show up on Paste only.
Those options tied to a tool. Watch out for it - there are a couple more tools with options bars which are only visible when you launch the specific tool.
