[solved] Exception occurred. Entity NOT saved:
cyclingskills
Post by cyclingskills » Mon Dec 11, 2017 4:20 pm
Hallo ich kann keine texte mehr speichern!
Versions
QCAD version: 3.19.1.0
Date: Nov 11 2017
Qt version: 5.6.2
Compiler version: Clang 6.0.0
Build Date: Nov 11 2017
Revision: 7cb021aef11c8ce056574d3b415ee66c7c96e10d
Architecture: x86_64
OS: macOS
OS version: macOS 10.13
Was ist da los?
DANKE für die rasche hilfe
Hi I can not save any Text in a drawing! not even in a new one. Allways the exception occured if you save it...
Tanks for helping
Regards Theo Stauffer
Re: Exception occurred. Entity NOT saved:
Post by andrew » Mon Dec 11, 2017 4:45 pm
What is the exact text you are trying to create (contents, fonts, size, etc.)?
cyclingskills
Post by cyclingskills » Mon Dec 11, 2017 5:42 pm
Hi it does not depends what vou type....
Bretter
Arial 40 Kursiv
source:
\fArial|b0|i0|c0|p0;Bretter
Kommando: new
Kommando: text
Kommando: save
Exception occurred. Entity NOT saved: 38
Zeichnung gespeichert: /Users/ts/Desktop/Parcours-Pläne/test2.dxf
Format: R27 [2013] DXF Drawing [Teigha] (*.dxf)
Post by andrew » Mon Dec 11, 2017 5:47 pm
Do you use a drawing as default template when starting a new drawing?
Edit > Application Preferences > File > Templates > Default Template
cyclingskills
Post by cyclingskills » Mon Dec 11, 2017 7:06 pm
No
Post by andrew » Tue Dec 12, 2017 10:06 am
Unfortunately, this is not reproducible here. Can you save your file as follows and attach it to your post:
- File > New
- Add text
- File > Save As...
- Change "Format" at the bottom to "R15 [2000/LT2000] DXF Drawing [dxflib] (*.dxf)"
cyclingskills
Post by cyclingskills » Tue Dec 12, 2017 10:14 am
OK here is the file
test.dxf
(190.26 KiB) Downloaded 402 times
cyclingskills
Post by cyclingskills » Tue Dec 12, 2017 10:15 am
Exception occurred. Entity NOT saved: 1ea
Zeichnung gespeichert: /Users/ts/Downloads/test.dxf
Format: R15 [2000/LT2000] DXF Drawing [Teigha] (*.dxf)
cyclingskills
Post by cyclingskills » Tue Dec 12, 2017 10:17 am
Sorry
Speichere mit Dateiformat Version 'R15 [2000/LT2000] DXF Drawing [dxflib] (*.dxf)'.
Schwarze Objekte und Layer werden als weiss gespeichert.
Benutzerdefinierte Farben werden auf die nächste verfügbare Farbe 'gerundet'.
Zeichnung gespeichert: /Users/ts/Downloads/test2.dxf
Format: R15 [2000/LT2000] DXF Drawing [dxflib] (*.dxf)
test2.dxf
(27.84 KiB) Downloaded 395 times
cyclingskills
Post by cyclingskills » Tue Dec 12, 2017 10:22 am
if I open the test.dxf no text is in it
if I open the test2.dxf text is in it!!!
Format library ? Teigha problem?
with format dxflib it works..
Post by andrew » Tue Dec 12, 2017 10:29 am
Thanks. I can reproduce the problem now. Please change the line spacing in the text dialog to a value of 4 or under. The DXF standard only allows values up to 4 and Teigha enforces this rule in the latest version which is unfortunate. I will look into ways to allow QCAD to work around that unnecessary limitation.
cyclingskills
Post by cyclingskills » Tue Dec 12, 2017 10:39 am
Great, thanks for your help. I tried a lot of settings... but this one not...
Regards Theo
