Layers in exported PDF
Post by andrew » Thu Jul 20, 2017 2:12 pm
From a QCAD user:
When exporting a drawing with layers to PDF there are no layers in the PDF file.
Re: Layers in exported PDF
Post by andrew » Thu Jul 20, 2017 2:14 pm
QCAD does not export layer information to PDF. The reason being that the toolkit we use for PDF export (Qt) does not have any support for exporting layers.
