Scale issue afetr upgrade to quadcam 3.15.5
cmcgrath5035
Post by cmcgrath5035 » Mon Jun 12, 2017 9:09 pm
I have a large file developed as part of a house build project.
Running quadcam pro on OPENSUSE 42.2
I recently upgraded from 3.14.0-pro-linux-x86_64 to 3.15.5-pro-linux-x86_64
In the drawing, I have Drawing Preferences:General:Drawing Unit set to foot and Paper Unit set to Inch.
Everything fine in 3.14.0
When I open the file in 3.15.5, it seems to have opened assuming Drawing Unit set to inch, all dimensions are /12.
Am I doing something wrong?
It seems that Application Preferences are being applied to this existing file
Re: Scale issue afetr upgrade to quadcam 3.15.5
Post by andrew » Mon Jun 12, 2017 9:12 pm
Please attach or e-mail your drawing file, so we can help efficiently, thanks.
cmcgrath5035
Post by cmcgrath5035 » Mon Jun 12, 2017 9:28 pm
Post by andrew » Tue Jun 13, 2017 9:37 am
I can confirm that this behavior has indeed changed in order to be compatible with other DXF/DWG applications. Even if the drawing unit is set to "Foot", the drawing unit is assumed to be "Inches" if the linear dimension format is set to "Architectural" or "Engineering".
This compatibility fix was introduced in QCAD version 3.14.3.
To port your drawing, please proceed as follows:
- Load the drawing
- Edit > Convert Drawing Unit
- Click check mark to start conversion
This might take several minutes. Your drawing unit will be Inch after this (the only unit you can use if the dimension format is "Architectural". You can still enter measurements and coordinates in feet using one of the following notations:
1'
1'6"
1'6 1/2"
cmcgrath5035
Post by cmcgrath5035 » Tue Jun 13, 2017 10:56 am
OK, thanks for the explanation.
I did not want to convert if this was a transient issue.
cmcgrath5035
Post by cmcgrath5035 » Tue Jun 13, 2017 5:33 pm
- Load the drawing
There is no such command under the Menu-Edit in QuadCam 3.15.5.0
cmcgrath5035
Post by cmcgrath5035 » Tue Jun 13, 2017 5:53 pm
Forget it - I realized I had a copy of qcad 3.16.7 (incorrect update a while ago) and it had the Edit-convert drawing unit.
All set
