[solved] pdf losing some polylines
jackieh
Post by jackieh » Tue May 16, 2017 10:24 pm
Hi again
Another strange pdf problem, I'm afraid. When I try to make a pdf, a few of my lines go missing (not many, but they are there for a reason!). It happens both on screen and on opening the pdf. I'd attach the dxf file, but it's larger than allowed (2.2MB), so instead I've attached a word document with a couple of screen prints.
I hope this has a very easy solution, and looking forward to hearing from you.
Jackie
pdf problem.docx
(383.43 KiB) Downloaded 359 times
Re: pdf losing some polylines
Post by Husky » Tue May 16, 2017 10:43 pm
dxf requested via PM.
Post by Clive » Wed May 17, 2017 10:47 am
Hi Jackieh
Can you copy and paste only the problem lines/entities into a new drawing and upload for testing please.
jackieh
Post by jackieh » Wed May 17, 2017 12:38 pm
Hi
I've attached the drawing, with just the lines, but the properties of have not been preserved - and it works fine in pdf. AS a result, in the original dwg, I changed one of the lines from dash to continuous and that was also fine. So, the problem seems to be with having a dashed line.
Looking forward to a solution!
Thanks, Jackie
lines causing problems.dxf
(105.19 KiB) Downloaded 367 times
Post by Husky » Wed May 17, 2017 8:32 pm
Solved ...
... after adjusting a few "Linetype Scales" it was working as expected.
