Autosave warning ...
Post by Husky » Sat Sep 28, 2013 9:51 pm
XP/32 QCAD 3.3.2
Right now, during my session, I get a couple Autosave warnings. Why is that so? I'm working on attributes ...
Re: Autosave warning ...
Post by andrew » Sat Sep 28, 2013 10:07 pm
Three entities cannot be saved (the Teigha plugin reports an exception).
To check which ones, you can save the drawing under a new name and open it again in a new tab.
Such errors are due to invalid entities.
Ideally, this should not happen, as QCAD should prevent you from creating invalid entities. If you can figure out what type of entities were not saved, that might be helpful for me to fix the problem.
Post by Husky » Sat Sep 28, 2013 10:45 pm
Ok - the bad boy (entity) seems to be a line in a Library item.
If I insert this item ones in my drawing - I get one Saving Warning.
If I put the same item 5 times in my drawing - I get 5 warnings with 5 different numbers.
Post by andrew » Sun Sep 29, 2013 11:48 am
Thanks for the update. Can you attache that library item for testing? Thanks.
Post by Husky » Sun Sep 29, 2013 6:08 pm
Here it is:
test2.dxf
(97.26 KiB) Downloaded 534 times
Manual / Auto-save provides this warning:
Post by andrew » Sun Sep 29, 2013 10:26 pm
Thanks. It's a problem with the attributes that are created when the part is inserted. Their layer IDs can end up being invalid:
http://www.qcad.org/bugtracker/index.ph ... ask_id=932
Should be fixed for the next update, thanks for the report!
Post by Husky » Mon Sep 30, 2013 2:25 am
andrew wrote:Should be fixed for the next update
Nice, thank you!
