Scale my drawing for Example 2.5 is broken nothing happend - can somebody confirm this, too?
Mac OSX 10.8.5 QCAD 3.3.2
Scale is broken
Re: Scale is broken
Thanks for your report. Yes, I can confirm that problem.
A bug report has been created at:
http://www.qcad.org/bugtracker/index.ph ... ask_id=929
Workaround:
Make sure that the button with a chain on it, at the right of the scale inputs is not checked (not pushed), even when scaling with the same factor for X / Y.
Workaround:
- scale_dialog.png (49.2 KiB) Viewed 4108 times
