Just fetched qcad-3.1.3-pro-linux-x86_64.tar.gz and installed it. Everything fine, except the two info tools "i p" and "i e". angle etc. remain fine.
Clean installation, config wiped, still: start the application, select "i p" tool, on first click qcad hangs, with the empty drawing. Also it starts to eat memory, there must be a leak.
Actually, it doesnt hang, but gets so sluggish, only a little patience shows, the tools are working somehow, but the beam looks too big, does it? Screenshot attached.
Is it only with me, to see that? System is Ubuntu 12.04.
qCAD 3.1.3 info tools regression [solved]
- hungerburg
- Premier Member
- While memory leaking tool works sluggish as heck
- qCAD_Info_Tool_Hand.png (1.51 KiB) Viewed 6061 times
Re: qCAD 3.1.3 info tools regression
Yes, I can confirm this is a bug:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=847
This should be fixed in QCAD 3.1.4 (now available for download).
- hungerburg
- Premier Member
Fix confirmed, Thank You Andrew
