Screen freeze after editing
J-J
Post by J-J » Thu Dec 01, 2011 11:16 pm
I am still experiencing a freeze after using a few of the editing tools: move, mirror, rotate...A click on autozoom usually unlocks the process at once. If you wait, it can be several minutes before you can resume working. During this freeze, the tools on the left side of the screen are not active. The freeze seems to be longer when many entities are concerned.
Win7- 64 bit - 17Go memory - Quadro 600/ 1Go
Post by andrew » Thu Dec 01, 2011 11:29 pm
Please send drawing(s) that show that symptom to info [at] ribbonsoft [dot] com for testing, thanks.
Brass Monkey
Post by Brass Monkey » Sat Dec 24, 2011 1:30 pm
I have a similar problem which affects all drawings equally. The cursor freezes, buttons won't press, etc.
I found that minimizing the Qcad window and restoring it will unfreeze the whole thing. But this happens fairly frequently, maybe four or five times a day. No idea what causes it but at least it is quick to repair.
