QCad 3 RC1 doesn't start....
johnkelly
Post by johnkelly » Sat Nov 19, 2011 8:30 am
I have installed QCad on Win 7 64bit.
It did start and I could work with it. After changing a few settings
(colors, disabled the splash screen) QCad is now starting with the debugger
and then stopping.
A new installation did not help.
Regards
Olaf
Post by andrew » Sat Nov 19, 2011 11:01 am
If possible, please enter ".bt" into the command line of the debugger (at the right of "qsdb>") and then hit the Enter key. The debugger prints some output (backtrace) which you can then copy / paste here into the forum. I will then create a bug report based on that output and most likely will be able to tell you how to fix the problem. Thanks.
johnkelly
Post by johnkelly » Sat Nov 19, 2011 12:02 pm
Thats it...
Uncaught exception at scripts\autostart.js:298: TypeError: Result of expression 'splash' [undefined] is not an object.
298	        splash.showMessage(qsTr("Loading plugin translations...") + "\n" + plugin.getClassName(), Qt.AlignBottom);
qsdb> .bt
#0  loadTranslations(plugins = Plugin(actionText: '', groupName: scripts, filePath: scripts/Idle/Idle.js),Plugin(actionText: '', groupName: Idle, filePath: scripts/Idle/DefaultAction/DefaultAction.js),Plugin(actionText: '', groupName: Idle, filePath: scripts/Idle/Reset/Reset.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/File/File.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/AutoSave/AutoSave.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/BitmapExport/BitmapExport.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/CloseFile/CloseFile.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/Compare/Compare.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/NewFile/NewFile.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/NewFromTemplate/NewFromTemplate.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/OpenFile/OpenFile.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/PdfExport/PdfExport.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/Print/Print.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/PrintPreview/PrintPreview.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/Quit/Quit.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/RecentFiles/RecentFiles.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/Save/Save.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/SaveAs/SaveAs.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/SvgExport/SvgExport.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/SvgExportAs/SvgExportAs.js),Plugin(actionText: '', groupName: File, filePath: scripts/File/SvgImport/SvgImport.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Edit/Edit.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/AppPreferences/AppPreferences.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Copy/Copy.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/CopyWithReference/CopyWithReference.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Cut/Cut.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/CutWithReference/CutWithReference.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Delete/Delete.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/DrawingPreferences/DrawingPreferences.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/ColorSettings/ColorSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/DimensionSettings/DimensionSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/GridSettings/GridSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/LinetypeSettings/LinetypeSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/MultiPageSettings/MultiPageSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/PageSettings/PageSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/PageTagSettings/PageTagSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/Template/Template.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/UnitSettings/UnitSettings.js),Plugin(actionText: '', groupName: DrawingPreferences, filePath: scripts/Edit/DrawingPreferences/ViewportSettings/ViewportSettings.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Esc/Esc.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/InsertBlockItem/InsertBlockItem.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/InsertScriptItem/InsertScriptItem.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Paste/Paste.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Redo/Redo.js),Plugin(actionText: '', groupName: Edit, filePath: scripts/Edit/Undo/Undo.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/View/View.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/AddView/AddView.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/AutoZoom/AutoZoom.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/CommandLineFocus/CommandLineFocus.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/DraftMode/DraftMode.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/EditView/EditView.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/PanZoom/PanZoom.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/Pick/Pick.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/PreviousView/PreviousView.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/Remove/Remove.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ShowLibraryBrowser/ShowLibraryBrowser.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ToggleGrid/ToggleGrid.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ToggleStatusBar/ToggleStatusBar.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ViewToolbars/ViewToolbars.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/WindowZoom/WindowZoom.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ZoomIn/ZoomIn.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ZoomOut/ZoomOut.js),Plugin(actionText: '', groupName: View, filePath: scripts/View/ZoomToSelection/ZoomToSelection.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Select/Select.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/AdvancedSelection/AdvancedSelection.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/DeselectAll/DeselectAll.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/InvertSelection/InvertSelection.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectAll/SelectAll.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectContour/SelectContour.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectIntersectedEntities/SelectIntersectedEntities.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectLayer/SelectLayer.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectPolygon/SelectPolygon.js),Plugin(actionText: '', groupName: Select, filePath: scripts/Select/SelectRectangle/SelectRectangle.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Draw/Draw.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Arc/Arc.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/Arc2PA/Arc2PA.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/Arc2PR/Arc2PR.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/Arc3P/Arc3P.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/ArcConcentric/ArcConcentric.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/ArcConcentricThrough/ArcConcentricThrough.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/ArcCPA/ArcCPA.js),Plugin(actionText: '', groupName: Arc, filePath: scripts/Draw/Arc/ArcTangential/ArcTangential.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Circle/Circle.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/Circle2P/Circle2P.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/Circle2PR/Circle2PR.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/Circle3P/Circle3P.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/CircleConcentric/CircleConcentric.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/CircleConcentricThrough/CircleConcentricThrough.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/CircleCP/CircleCP.js),Plugin(actionText: '', groupName: Circle, filePath: scripts/Draw/Circle/CircleCR/CircleCR.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Dimension/Dimension.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimAligned/DimAligned.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimAngular/DimAngular.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimDiametric/DimDiametric.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimHorizontal/DimHorizontal.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimOrdinate/DimOrdinate.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimRadial/DimRadial.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimRotated/DimRotated.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/DimVertical/DimVertical.js),Plugin(actionText: '', groupName: Dimension, filePath: scripts/Draw/Dimension/Leader/Leader.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Ellipse/Ellipse.js),Plugin(actionText: '', groupName: Ellipse, filePath: scripts/Draw/Ellipse/EllipseArcCPPA/EllipseArcCPPA.js),Plugin(actionText: '', groupName: Ellipse, filePath: scripts/Draw/Ellipse/EllipseCPP/EllipseCPP.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Hatch/Hatch.js),Plugin(actionText: '', groupName: Hatch, filePath: scripts/Draw/Hatch/HatchDialog/HatchDialog.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Image/Image.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Line/Line.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/Line2P/Line2P.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineAngle/LineAngle.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineBisector/LineBisector.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineFreehand/LineFreehand.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineHorizontal/LineHorizontal.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineOrthogonal/LineOrthogonal.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineParallel/LineParallel.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineParallelThrough/LineParallelThrough.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LinePolygonCP/LinePolygonCP.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LinePolygonPP/LinePolygonPP.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineRectangle/LineRectangle.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineRectangleSize/LineRectangleSize.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineRelativeAngle/LineRelativeAngle.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineTangent1/LineTangent1.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineTangent2/LineTangent2.js),Plugin(actionText: '', groupName: Line, filePath: scripts/Draw/Line/LineVertical/LineVertical.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Point/Point.js),Plugin(actionText: '', groupName: Point, filePath: scripts/Draw/Point/Point1P/Point1P.js),Plugin(actionText: '', groupName: Point, filePath: scripts/Draw/Point/PointMN/PointMN.js),Plugin(actionText: '', groupName: Point, filePath: scripts/Draw/Point/PointNP/PointNP.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Polyline/Polyline.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/DrawPolyline/DrawPolyline.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineAppendNode/PolylineAppendNode.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineDeleteNode/PolylineDeleteNode.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineDeleteNodesBetween/PolylineDeleteNodesBetween.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineEquidistant/PolylineEquidistant.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineFromSegments/PolylineFromSegments.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineInsertNode/PolylineInsertNode.js),Plugin(actionText: '', groupName: Polyline, filePath: scripts/Draw/Polyline/PolylineTrim/PolylineTrim.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Spline/Spline.js),Plugin(actionText: '', groupName: Spline, filePath: scripts/Draw/Spline/SplineControlPoints/SplineControlPoints.js),Plugin(actionText: '', groupName: Spline, filePath: scripts/Draw/Spline/SplineFitPoints/SplineFitPoints.js),Plugin(actionText: '', groupName: Draw, filePath: scripts/Draw/Text/Text.js),Plugin(actionText: '', groupName: Text, filePath: scripts/Draw/Text/TextDialog/TextDialog.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Modify/Modify.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Align/Align.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Bevel/Bevel.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/BreakOut/BreakOut.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Divide/Divide.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Duplicates/Duplicates.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/EditText/EditText.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Explode/Explode.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/ExplodeText/ExplodeText.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/IsoProject/IsoProject.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Lengthen/Lengthen.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Mirror/Mirror.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Reverse/Reverse.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Rotate/Rotate.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Rotate2/Rotate2.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Round/Round.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Scale/Scale.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/SplitIntoEqualParts/SplitIntoEqualParts.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Stretch/Stretch.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/ToBack/ToBack.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/ToFront/ToFront.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Translate/Translate.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/TranslateRotate/TranslateRotate.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/Trim/Trim.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/TrimBoth/TrimBoth.js),Plugin(actionText: '', groupName: Modify, filePath: scripts/Modify/ZeroLengthDetection/ZeroLengthDetection.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Snap/Snap.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/LockRelativeZero/LockRelativeZero.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/RestrictHorizontal/RestrictHorizontal.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/RestrictOff/RestrictOff.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/RestrictOrthogonal/RestrictOrthogonal.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/RestrictVertical/RestrictVertical.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SetRelativeZero/SetRelativeZero.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapAuto/SnapAuto.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapCenter/SnapCenter.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapCoordinate/SnapCoordinate.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapCoordinatePolar/SnapCoordinatePolar.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapDistance/SnapDistance.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapEnd/SnapEnd.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapFree/SnapFree.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapGrid/SnapGrid.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapIntersection/SnapIntersection.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapIntersectionManual/SnapIntersectionManual.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapMiddle/SnapMiddle.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapMiddleManual/SnapMiddleManual.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapOnEntity/SnapOnEntity.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapPerpendicular/SnapPerpendicular.js),Plugin(actionText: '', groupName: Snap, filePath: scripts/Snap/SnapReference/SnapReference.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Information/Information.js),Plugin(actionText: '', groupName: Information, filePath: scripts/Information/InfoAngle/InfoAngle.js),Plugin(actionText: '', groupName: Information, filePath: scripts/Information/InfoArea/InfoArea.js),Plugin(actionText: '', groupName: Information, filePath: scripts/Information/InfoDistanceEP/InfoDistanceEP.js),Plugin(actionText: '', groupName: Information, filePath: scripts/Information/InfoDistancePP/InfoDistancePP.js),Plugin(actionText: '', groupName: Information, filePath: scripts/Information/InfoTotalLength/InfoTotalLength.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Layer/Layer.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/AddLayer/AddLayer.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/EditLayer/EditLayer.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/HideAllLayers/HideAllLayers.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/RemoveLayer/RemoveLayer.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/ShowActiveLayer/ShowActiveLayer.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/ShowAllLayers/ShowAllLayers.js),Plugin(actionText: '', groupName: Layer, filePath: scripts/Layer/ToggleLayerVisibility/ToggleLayerVisibility.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Block/Block.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/AddBlock/AddBlock.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/CreateBlock/CreateBlock.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/EditBlock/EditBlock.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/EditFromInsert/EditFromInsert.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/EditMainDrawing/EditMainDrawing.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/HideAllBlocks/HideAllBlocks.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/Insert/Insert.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/RemoveBlock/RemoveBlock.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/RenameBlock/RenameBlock.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/ShowAllBlocks/ShowAllBlocks.js),Plugin(actionText: '', groupName: Block, filePath: scripts/Block/ToggleBlockVisibility/ToggleBlockVisibility.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Window/Window.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/Cascade/Cascade.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/CloseAll/CloseAll.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/FullScreen/FullScreen.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/Next/Next.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/Previous/Previous.js),Plugin(actionText: '', groupName: Window, filePath: scripts/Window/Tile/Tile.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Widgets/Widgets.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/AutoZoomView/AutoZoomView.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/BlockList/BlockList.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/CadToolBar/CadToolBar.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/ClipboardDisplay/ClipboardDisplay.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/CommandLine/CommandLine.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/CoordinateDisplay/CoordinateDisplay.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/DirectoryList/DirectoryList.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/FirstStart/FirstStart.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/GraphicsView/GraphicsView.js),Plugin(actionText: '', groupName: GraphicsView, filePath: scripts/Widgets/GraphicsView/Colors/Colors.js),Plugin(actionText: '', groupName: GraphicsView, filePath: scripts/Widgets/GraphicsView/Fonts/Fonts.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/HelpViewer/HelpViewer.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/LayerList/LayerList.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/MouseDisplay/MouseDisplay.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/OptionsToolBar/OptionsToolBar.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/PenToolBar/PenToolBar.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/ProgressBar/ProgressBar.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/PropertyEditor/PropertyEditor.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/SelectionDisplay/SelectionDisplay.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/TabBar/TabBar.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/TrialTeaser/TrialTeaser.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/ViewList/ViewList.js),Plugin(actionText: '', groupName: Widgets, filePath: scripts/Widgets/Viewport/Viewport.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Examples/Examples.js),Plugin(actionText: '', groupName: Examples, filePath: scripts/Examples/DrawExamples/DrawExamples.js),Plugin(actionText: '', groupName: DrawExamples, filePath: scripts/Examples/DrawExamples/DrawBoundingBox/DrawBoundingBox.js),Plugin(actionText: '', groupName: Examples, filePath: scripts/Examples/MathExamples/MathExamples.js),Plugin(actionText: '', groupName: MathExamples, filePath: scripts/Examples/MathExamples/Spiral/Spiral.js),Plugin(actionText: '', groupName: Examples, filePath: scripts/Examples/Tutorials/Tutorials.js),Plugin(actionText: '', groupName: Tutorials, filePath: scripts/Examples/Tutorials/CommandLineTools/CommandLineTools.js),Plugin(actionText: '', groupName: CommandLineTools, filePath: scripts/Examples/Tutorials/CommandLineTools/CreatingDrawing/CreatingDrawing.js),Plugin(actionText: '', groupName: CommandLineTools, filePath: scripts/Examples/Tutorials/CommandLineTools/ExPdfExport/ExPdfExport.js),Plugin(actionText: '', groupName: CommandLineTools, filePath: scripts/Examples/Tutorials/CommandLineTools/ExSvgExport/ExSvgExport.js),Plugin(actionText: '', groupName: Tutorials, filePath: scripts/Examples/Tutorials/MenusAndToolBars/MenusAndToolBars.js),Plugin(actionText: '', groupName: Tutorials, filePath: scripts/Examples/Tutorials/PersistentWidgets/PersistentWidgets.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Help/Help.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/About/About.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/CheckForUpdates/CheckForUpdates.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/FAQ/FAQ.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/Forum/Forum.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/HelpContents/HelpContents.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/Purchase/Purchase.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/ReportBug/ReportBug.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/ShowReadme/ShowReadme.js),Plugin(actionText: '', groupName: Help, filePath: scripts/Help/Website/Website.js),Plugin(actionText: '', groupName: ImportExport, filePath: scripts/ImportExport/DwgExporter/DwgExporter.js),Plugin(actionText: '', groupName: ImportExport, filePath: scripts/ImportExport/DwgImporter/DwgImporter.js),Plugin(actionText: '', groupName: ImportExport, filePath: scripts/ImportExport/DxfImporter/DxfImporter.js),Plugin(actionText: '', groupName: ImportExport, filePath: scripts/ImportExport/SvgExporter/SvgExporter.js),Plugin(actionText: '', groupName: ImportExport, filePath: scripts/ImportExport/SvgImporter/SvgImporter.js),Plugin(actionText: '', groupName: Navigation, filePath: scripts/Navigation/DefaultNavigation/DefaultNavigation.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Preferences/Preferences.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Input/Input.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Language/Language.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Scripting/Scripting.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Shortcuts/Shortcuts.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Start/Start.js),Plugin(actionText: '', groupName: Preferences, filePath: scripts/Preferences/Styles/Styles.js),Plugin(actionText: '', groupName: scripts, filePath: scripts/Tools/Tools.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/Dwg2Bmp/Dwg2Bmp.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/Dwg2Pdf/Dwg2Pdf.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/Dwg2Svg/Dwg2Svg.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/LibraryBrowser/LibraryBrowser.js),Plugin(actionText: '', groupName: LibraryBrowser, filePath: scripts/Tools/LibraryBrowser/EditMetaData/EditMetaData.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/LibraryTranslator/LibraryTranslator.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/PainterPathViewer/PainterPathViewer.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/PartGenerator/PartGenerator.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/QBook/QBook.js),Plugin(actionText: '', groupName: Tools, filePath: scripts/Tools/Ui2Png/Ui2Png.js), splash = undefined) at scripts\autostart.js:298
#1  main() at scripts\autostart.js:480
#2  <global>() at scripts\autostart.js:588
Regards
Olaf
Post by andrew » Sat Nov 19, 2011 3:28 pm
Thanks. It's a combination of disabling the splash screen and choosing a user interface language other than English that produces this problem.
- You can reset QCAD 3 by deleting its configuration file at:
C:\Documents and Settings\yourname\Application Data\RibbonSoft\QCAD3.ini
or
- Edit this same configuration file to change the language back to English:
[Language]
UiLanguage=en
or
- Force the language to English using the command line argument -locale:
qcad.exe -locale en
or of course wait for the update for QCAD 3 (RC2) which will also fix the problem.
johnkelly
Post by johnkelly » Sat Nov 19, 2011 4:54 pm
Thanks will try it
Regards and have a good weekend
Olaf
