QCAD3 RC1 issue opening existing file
cmcgrath5035
Post by cmcgrath5035 » Sun Nov 13, 2011 2:08 pm
I have a file created with QCAD 2.2 that I have tried with 3.0B3 and it opened fine. I did not test there extensively.
I just downloaded 3.0RC1, and when I open the file some parts of a block I use from the Library (an A3 template) don't scale correctly, while other parts do.
I was "just learning" blocks when I made the edits, so may have done something incorrectly, but 2.2 and 3.0B3 were OK with it.
If you want to look at the file, let me know.
Post by andrew » Sun Nov 13, 2011 8:06 pm
Yes, please send the file to [email protected] if possible for testing, thanks.
Brass Monkey
Post by Brass Monkey » Wed Nov 23, 2011 1:12 pm
I have this problem too, also when scaling a template as a group or object rather than a block. The text components do not scale at all well and lose their position relative to the lines.
Post by andrew » Wed Nov 23, 2011 1:15 pm
It's a known problem and fixed for the next release:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=385
