QCAD version 3.29.4
Warning: QSocketNotifier: Can only be used with threads started with QThread
00:35:24: Debug: loading plugins...
00:35:25: Debug: RDwgPlugin::init: trial
00:35:25: Debug: RPolygonPlugin::init
00:35:25: Debug: RProScriptsPlugin::init: trial
00:35:25: Debug: RTracePlugin::init: trial
00:35:25: Debug: loading static plugins...
00:35:25: Debug: Renaming old unversioned config file from '/home/daniel/.config/QCAD/QCAD3.conf' to '/home/daniel/.config/QCAD/QCAD3_old.conf'
Warning: Failed to load client buffer integration: "wayland-egl"
Warning: Available client buffer integrations: ()
Warning: No shell integration named "xdg-shell" found
Warning: No shell integration named "xdg-shell-v6" found
Warning: No shell integration named "wl-shell" found
Warning: No shell integration named "ivi-shell" found
Warning: Loading shell integration failed.
Warning: Attempted to load the following shells ("xdg-shell", "xdg-shell-v6", "wl-shell", "ivi-shell")
