qcad 3.29.2 layer states / layer group issue
tkyler
Post by tkyler » Fri Jan 19, 2024 11:26 pm
Thx for the update gents, is is always appreciated.
1) It seems as though the layer states from documents I've authored in 3.28 are not showing up in 3.29.2. Is there a back door way to sneak those in perhaps? or just have to reset the states and create new ones. I didn't see this in the bug list so checking here...I can log it if you feel its valid.
2) Also, layer groups are not present in the layer list, its just a 'flat list'. If I right-click on a layer named "parent" and select "add sublayer" and name the new layer "child", then the newly created layer is named "parentchild" and is on the same level as 'parent' and not nested...so toggling the visibility of 'parent' does not affect 'parentchild', etc. See screenshot below of the exact same DXF file opened in 3.28 (on left) and 3.29 (on right)
Thx.
OSX 14.1.1 / Mac M1 / 3.29.2
tkyler
Re: qcad 3.29.2 layer states / layer group issue
Post by CVH » Sun Jan 21, 2024 10:48 am
Are you sure that you use QCAD Pro?
See menu Help .. About
Hierarchical layers are not supported by QCAD CE.
Are you sure that the use of hierarchical layers is not disabled?
See menu Edit .. Application Preferences .. Widgets .. Layer List
# EDIT # This is probably answered on another topic and not cross referenced, see:
https://qcad.org/rsforum/viewtopic.php? ... 576#p43405
