qcad-cam 3.29.0 - New from template issue
jbergen
Post by jbergen » Mon Jan 15, 2024 8:21 pm
I just upgraded to qcad-cam pro version 3.29.0 and when I choose "File - New from template" the program does not give me a "Create New Drawing from Template" dialog box. Instead I just get a spinning cursor.
Linux Mint 21.2
qcad-cam 3.29.0 qt5 version
Same results under Windows 10
Re: qcad-cam 3.29.0 - New from template issue
Post by andrew » Tue Jan 16, 2024 2:10 pm
Thanks.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2515
This should be fixed in 3.29.1 released today.
jbergen
Post by jbergen » Tue Jan 16, 2024 4:45 pm
Thanks for the quick fix, Andrew! Wow that was quick. It's working great now.
And a huge thank you for QCAD itself. I have been using QCAD full-time for nearly 2 years now, and I absolutely love it. It's a joy to use and it's perfect for my application (making templates for boat builders). You've done an outstanding job. Please keep up the good work.
Post by andrew » Wed Jan 17, 2024 9:47 am
Thank you for your kind feedback. We will keep it up and indeed already have a lot of plans for QCAD moving forward. Moving to Qt 6 being the main roadmap.
