Use Greek math symbols to my text
jocpo
Post by jocpo » Wed Apr 19, 2023 4:37 pm
MacOS Monterey
QCAD PPO Version:3.26.2.0 (3.26.2)
I want to use the theta (𝜽) symbol in text formulas I'm adding to my drawing. How do I do this? Also what about PI and other common symbols?
In a previous version of QCAD I use with a macOS Mojave drive a variety of math symbols are available in the text window.
Any help regarding this matter would be appreciated.
Re: Use Greek math symbols to my text
Post by CVH » Wed Apr 19, 2023 5:17 pm
This should be available in the Text Editor .. Right high .. The Omega button (Specials Characters)
Last listed is 'Others' and that opens a character map.
A more extensive list is available with a right click on the Label field of a Dimension entity .. Insert Symbol
On creation in the Options Toolbar and afterwards in the Property Editor.
If these don't show on a MacOS then I would consider filing a Bug Report: https://www.ribbonsoft.com/bugtracker/
You need a separate account there or register for a new one.
