[Solved}Block Properties documentation
DaleEltoft
Post by DaleEltoft » Sat Feb 04, 2023 11:23 pm
Where can I find an explanation of the Properties for things where the choices are "By Layer" or "By Block"? This seems even more confusing when dealing with Blocks which seem to have a mix of properties from the drawing and the block.
I've looked through the Help and the Introduction book for an explanation but didn't find anything.
Re: Block Properties documentation
Post by Husky » Sat Feb 04, 2023 11:49 pm
Maybe this tutorial will shed some light into this matter:
https://www.qcad.org/en/tutorial-layers ... attributes
DaleEltoft
[Solved] Block Properties documentation
Post by DaleEltoft » Sun Feb 05, 2023 1:39 am
It did shed light. Now I'm like a deer in the headlights. It helped to do the example for myself. :shock:
