Parallel line tool question
mbcarpenter
Post by mbcarpenter » Thu Feb 02, 2023 5:21 pm
Mac OS 10.13.6
QCad/Cam 3.27.8.0
When I’m using the parallel line with distance sometimes it draws the line the correct distance away other times it doesn’t. I’m just a beginner with cad I’m figuring it something I’m doing wrong but not sure what. Any help would greatly appreciated
Mike
Re: Parallel line tool question
Post by andrew » Thu Feb 02, 2023 6:37 pm
Please attach the file of a drawing where you think it does not work as expected and indicate which line is affected and what distance you enter. Please be as precise and specific as possible in describing your problem.
Note that the parallel is constructed to the line that is next to the cursor when clicking, so perhaps the cursor is next to another line.
mbcarpenter
Post by mbcarpenter » Thu Feb 02, 2023 7:57 pm
The 40'4" at the front i parallel the left vertical 10'7" and i get into do it.I move to the other vertical line at the and parallel it to 10'61/2"and get12"61/2".That gives me 17'21/2"in the center. What i'm trying to get is 10'7"- 19'21/2"-10'61/2".I have tried doing it a few ways using different lines to parallel off of. One of them works but then i try another one and get a measurement that doesn't add up either. I'm really new at this i appreciate the help. hope I've given enough information and it makes sense
thanks mike
Heather Hill 1.dxf
(119.3 KiB) Downloaded 139 times
Post by CVH » Thu Feb 02, 2023 8:30 pm
I get a distance of 10'-6 1/2" [126.5"] when I enter 10'6+1/2" or 10'6 1/2" or 10' 6 1/2" in the Option Toolbar.
But I get the same 12'-6 1/2" when I enter 10'61/2" ... :shock:
If we break it down: 10' + 61/2" = 10' + 30.5" = 10' + 2' + 6.5" = 12' + 6.5" :lol:
mbcarpenter
Post by mbcarpenter » Thu Feb 02, 2023 9:31 pm
I just tried it using 126.5" and it worked that way. Just don't understand why.In your opinion would you just stay with using inches instead of feet and inches.I'm bring to learn anyway i can. Thanks so much for reply.
mike
Post by CVH » Thu Feb 02, 2023 9:43 pm
It seems to treat 10'61/2" as 10 feet and 61 inches divided by 2.
A collision between interpreting feet/inch and doing calculations with arithmetic functions like +-*/ and so on.
I am a metric guy ... Don't ask me. :lol:
Just take care to add spaces but not the minus symbol between feet and inches that we see in dimension labels.
Sure, 126.5" is valid too. :wink:
mbcarpenter
Post by mbcarpenter » Fri Feb 03, 2023 3:06 am
Thanks for your help. I made some good progress this evening.
Mike
