I want to print all the block elements at once using the command line tool.
But I have to enter every block one by one using comma. Any other way?
[solved] I want to print all block elements.
- 블록요소.png (12.62 KiB) Viewed 1503 times
Re: I want to print all block elements.
The block list may contain regular expressions:
https://www.qcad.org/en/products/qcad-c ... ls#dwg2pdf
To print / export all blocks, you can use the regular expression ".*"
dwg2pdf -o allblocks.pdf -block=".*" input.dxf
that's not working
I tried to print all the elements in the flange.png example.
But the result is coming out like result.png.
- result.png (39.05 KiB) Viewed 1476 times
- flange.png (92.86 KiB) Viewed 1476 times
The dwg2pdf example above produces a PDF with one block from the drawing file per page.
The model space of a drawing is a block (as shown in your result.png). Layout spaces are other blocks (as shown in your flange.png).
Perhaps, you can elaborate on what you are trying to do as I think we are talking about different things.
you are right.
you are right.
I wanted to print all layouts and blocks
