[solved] Text using Splines
thelasercutter01
Post by thelasercutter01 » Tue Jan 24, 2023 12:46 pm
Is there an easy way to create text using lines, splines and other tools rather than manually trying to draw text?
Why do I need it when there is text tool available?
What I need output to the laser is single line text (see image named SingleLineText ).
If I use text in QCAD and Explode it, it always comes as double lines (See ExplodedText.dxf). I can edit it bit its messy after exploding.
ExplodedText.dxf
(99.79 KiB) Downloaded 138 times
SingleLineText.dxf
(96.68 KiB) Downloaded 136 times
Re: Text using Splines
Post by andrew » Tue Jan 24, 2023 1:26 pm
You could use the single line CXF fonts that come with QCAD. For example Standard or GreekS_OL. You can also explode these into polylines.
Post by andrew » Tue Jan 24, 2023 1:28 pm
You can also edit the glyphs in these fonts or create your own fonts using QCAD:
https://www.qcad.org/en/tutorial-editing-cxf-fonts
thelasercutter01
Post by thelasercutter01 » Tue Jan 24, 2023 2:05 pm
Wow, that worked so well.
Thanks for your incredible support on the forum, its really appreciated.
