select block origin (solved)
bambuko
Senior Member
Post by bambuko » Fri Jan 13, 2023 5:10 pm
Editing block (BE) - want to select block origin to create a line through...
How do I, please select point/block origin?
is it possible?
At the moment I am using Edit block in place (BB) to find a point by reference to other geometry.
There are other ways... but I would like to pick/select block origin as a point?
QCAD Professional
Version: 3.27.8.0 (3.27.8)
Internet: QCAD.org
Build Date: Oct 6 2022
Revision: dea3962
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
QCad Pro
Linux MX-21.3 "Wildflower"
Re: select block origin
Post by andrew » Fri Jan 13, 2023 5:20 pm
The origin of a block is usually at 0/0 when editing the block.
If you cannot solve the problem, please attach the drawing file in question and elaborate on what you are trying to do.
bambuko
Senior Member
Post by bambuko » Fri Jan 13, 2023 10:24 pm
Thanks!
worked it out ... eventually e_confused
sorry for being so dumb :? :oops:
QCad Pro
