Y+ and B+ keyboard shortcuts
ryancousins
Post by ryancousins » Tue Dec 20, 2022 3:48 am
Win11 Pro
QCAD 3.27.8
Okay, I feel really dumb asking this, but how do you make the Y+/Y- and B+/B- shortcuts work? I've tried both sets of plus and minus keys on my keyboard and I've tried adding other modifier keys while pressing +/- with no luck. I know there are alternate shortcuts for select layer entities or select block references, but I can't leave this little mystery unsolved.
Re: Y+ and B+ keyboard shortcuts
Post by Husky » Tue Dec 20, 2022 6:21 am
... but how do you make the Y+/Y- and B+/B- shortcuts work?
Y+/Y- was addressed and fixed after my report in the bugtracker:
https://www.qcad.org/bugtracker/index.p ... sk_id=2413
Most likely available with the next QCAD release.
I don't know if B+/B- was addressed by that too but maybe you could leave a hint at my bugreport. :wink:
Anyway - B+ has an alternative shortcut B[ and B- would be B]
Post by CVH » Tue Dec 20, 2022 9:40 am
I usually use the Context Menu with a right-click on the Block name in question because you need to select a Block in the Block List too.
Similar for Layers.
Y+/Y- and B+/B- shortcuts don't work but it is functional by the menu items.
I am able to deselect Blocks with 'B]' but it is not a two-key-stroke over here e_confused , I need <B> and then <Alt-Gr> + <]> to do that.
I cannot select Blocks with <B> and then <Alt-Gr> + <[>
ryancousins
Post by ryancousins » Tue Dec 20, 2022 1:48 pm
Thanks, guys. Based on Andrew's note on the bugtracker entry, it looks like Y+/Y- has been deprecated and we just use YC/YD now, and a new commit on GitHub shows that B+/B- is now BK/BX, respectively. Do I have that correct?
Post by CVH » Tue Dec 20, 2022 5:57 pm
Yes, if now means the next snapshot or the next release ... :lol: :wink:
Or if you copy over the GitHub files to the installation folder to supersede the compiled ones.
