Change polar reference to zero degrees is up, 180 is down
lines
Post by lines » Thu Dec 08, 2022 4:41 pm
I work in a world where up is zero degrees (and 360), 90 degrees is right, 180 is down and 270 is left.
Can I set this up as the default polar system?
QCad Pro 3.27.8.0
Windows 10 Pro
Re: Change polar reference to zero degrees is up, 180 is down
Post by CVH » Thu Dec 08, 2022 7:28 pm
Basic mathematics tells us that zero degrees is right ... East.
https://en.wikipedia.org/wiki/Unit_circle
An that is the way it is in QCAD.
The X-axis is horizontal and increasing values are to the right.
Zero degree is the positive X-axis and forward angles are pointing CCW.
As long as QCAD doesn't support an UCS there is little we can do.
BTW: It does support UCS internally while reading files but you can not alter that.
This said, there is a way around this:
https://www.qcad.org/rsforum/viewtopic. ... 2057#p2057
You are not alone on your quest:
https://www.qcad.org/rsforum/viewtopic.php?f=30&t=9088
lines
Post by lines » Thu Dec 08, 2022 7:52 pm
Thank you
Post by CVH » Thu Dec 08, 2022 7:57 pm
Maybe this is what you are looking for ...
https://www.qcad.org/rsforum/viewtopic. ... 488#p31488
