Using command line
DShum
Using command line
Post by DShum » Fri Dec 02, 2022 9:27 pm
In order to use the command line, I find that I have to first click on it to activate it. What am I missing?
I am using windows 10 and Version: 3.27.8.0 (3.27.8)
Re: Using command line
Post by andrew » Fri Dec 02, 2022 9:35 pm
This is by design as QCAD uses mostly two-letter shortcuts rather than commands. Shortcuts can be entered without the command line. Simply press the "L" key, then the "I" key to start drawing lines.
If you really need the command line (for example to enter coordinates), press the Spacebar to give it the focus.
DShum
Post by DShum » Fri Dec 02, 2022 9:51 pm
OK, Thank you.
I am accustomed to do a right click, select the command and start writing. So I need to hit the space bar to do that.
