[solved] Set specific angle measurements to whole numbers
Rick
Post by Rick » Fri Nov 25, 2022 11:48 pm
How do I set just measured angles to display in whole numbers with no decimal places?
If this can be done to specific measurements that would be great, if to all angles in the drawing that would be OK.
Version 3.25 on Win 10.
Thanks for your help!
Rick
Re: Set specific angle measurements to whole numbers
Post by Husky » Sat Nov 26, 2022 12:18 am
Hi Rick,
If this can be done to specific measurements that would be great, ...
Unfortunately not in your QCAD version. The current QCAD version would be able to do that.
... if to all angles in the drawing that would be OK.
Below Drawing Preferences you can set the precision global for all angular measurements to 0. That will give you what you are looking for. :wink:
Post by CVH » Sat Nov 26, 2022 6:17 am
If this can be done to specific measurements that would be great ...
The workaround in older versions would be to explode (XP) the specific dimension and alter the representation of the resulting text entity.
Exploded it is no longer a dimension.
Or you could update to the latest version of QCAD PRO off course. :wink:
The Community Edition doesn't support Dimension Style Overrides.
Rick
Post by Rick » Sat Nov 26, 2022 4:16 pm
Awesome!!!
Thanks Everyone.
Rick
