Solved-Aligning objects in viewports
Eelie
Post by Eelie » Mon Nov 21, 2022 12:22 am
How can I align objects between several viewports? For example, if I have four viewports in one drawing sheet arranged two wide by two high and each viewport shows a different elevation of the same building how can I properly align the elevations horizontally and vertically with each other? In a viewport, I can't select an individual ground line or wall line so I can't see how the ALIGN command can be used.
ryancousins
Re: Aligning objects in viewports
Post by ryancousins » Mon Nov 21, 2022 1:23 am
This is a bit of a workaround, but you can align your viewports, so if you kept a consistent distance between your viewport border and one of the edges of each part of your model (the bottom of each, for instance), this would indirectly cause your models to be aligned. Does that make sense?
Post by Husky » Mon Nov 21, 2022 2:41 am
In a selected Viewport entities become snappable:
Align Viewports.gif (650.46 KiB) Viewed 1472 times
If you then "Set Relative Zero" [RZ] to a convenient point you can align a viewport precisely with "Coordinate" [SX] in no time .
Eelie
Post by Eelie » Mon Nov 21, 2022 11:55 am
Thank you ryancousins and husky for your responses. That's very helpful.
