How to show only the drawing
- Active Member
Is there a function that shows only the drawing? In other words, a function that hides all toolbars and panes. If such a function exists, what is its keyboard shortcut?
Re: How to show only the drawing
Nope - unfortunately such a function doesn't exist in QCAD. Best what you can do is the "Full Screen" mode with Function key "F11".ouilogique wrote: ↑Sun Oct 02, 2022 3:37 pmIs there a function that shows only the drawing? In other words, a function that hides all toolbars and panes.
- Active Member
OK, thanks for your answer. I think everyone who works with QCAD on a laptop will be interested, so I asked for it in the suggestions section of the forum: https://www.qcad.org/rsforum/viewtopic.php?f=31&t=9577.
