[solved] Filter Only Within Selected Objects
Sometimes I need to run a filter within selected objects only. Is there a way to do this?
Currently when I run a filter command it operates on all of the entities displayed.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Re: Filter Only Within Selected Objects
The Selection Filter has 4 methods represented by icons:
- Replace Current
- Add
- Subtract
- Intersect
To filter within an existing selection one can use the Intersect method.
To filter out unwanted one uses the Subtract method.
No, unfortunately there is no way to do that. I would appreciate that option too ...
Also see:
https://qcad.org/doc/qcad/latest/refere ... tionFilter
... Usage ... 6 ... last line
Hmm I have to get my head around that suggestion
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Aha. Thank you CVH.CVH wrote: ↑Mon Sep 12, 2022 5:17 amAlso see:
The highlighted line in the manual allows me to do what I want.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Yeah I looked. Couldn't see the forest for the trees.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
Yep, me too. Thanks CVH for pointing that out.
