dwg2maptiles fonts
Ivan1
dwg2maptiles fonts
Post by Ivan1 » Sun Sep 04, 2022 11:45 am
Font cannot be displayed,How do I add new fonts to QCAD for dwg2maptiles.
Re: dwg2maptiles fonts
Post by CVH » Sun Sep 04, 2022 12:41 pm
QCAD uses the system fonts that are installed on your computer.
Besides that it will also look for fonts in the fonts folder under the installation path of QCAD.
As far as I know QCAD can not handle SHX files.
Ivan1
Post by Ivan1 » Sun Sep 04, 2022 1:14 pm
I copy windows\fonts\*.ttf to qcad\fonts sucessful.
Post by CVH » Sun Sep 04, 2022 1:27 pm
I am sure that copying files worked out but that is not required.
QCAD already had access to all the TTF fonts installed under Windows.
Your drawing file probably uses a font that is not installed on your computer.
In such a case one can:
or provide the missing font file. (as a system or as a custom font)
or one could substitute it with another suitable font that you have installed.
