[SOLVED] open file in last view
Graham
Post by Graham » Thu Aug 25, 2022 11:46 am
Hi All
Win 11 and latest QCAD
Is it possible to open a much used big detailed drawing in the last viewed or worked area instead of the whole drawing?
just to make life easier!!
Thank You
Graham
Re: open file in last view
Post by CVH » Thu Aug 25, 2022 4:38 pm
Not that I know of ... A drawing opens in Model_Space and auto zoomed.
There was recently already a question to open a drawing in the latest layout view ...
One can save more than one views with a drawing: View menu .. Stored Views .. Add View (VA).
There is the View List (GV).
With one to more clicks you can get the stored view back. :wink:
Post by Husky » Thu Aug 25, 2022 7:47 pm
Hi Graham,
Yes. In Application Preferences deactivate the option "Auto zoom on load" and relaunch QCAD. Drawings will then be open with the zoom factor there was saved with.
Graham
[SOLVED]: open file in last view(SOLVED)
Post by Graham » Sat Aug 27, 2022 11:03 am
Thank you all
Graham
