[solved] The dll file is missing
Hello
I installed QCAD 32-bit.
During startup, it displays the following message: api-ms-win-crt-runtime-l1-1-0.dll error
How to fix it?
Regards
How to fix it?
Regards
Re: The dll file is missing
I searched for the string "api-ms-win-crt" on the forum and got some similar hits.
Maybe there is a solution for you in there too.
In general, first download the msi installer and then run it from where you saved it.
Make sure you don't have older versions or the CE version installed.
Can you send a link to download the file ?.
Windows 7 Ultimate 32-bit version
Thank you.
Thank you.
Certina,
You are posting on the QCAD Professional forum.
You should have recieved a link to your personal download area.
An msi or a zip file can be found there.
Windows 7 is no longer being updated.
Thank you.
Thank you.
Try a manual installation with the archive / zip file packet:
deinstall the msi version
Download the 32bit ZIP Archive from your download link,
extract the file to C:\Program Files,
this will create a new folder below Program Files. Folder name qcad-3.27.6-pro-win32
open this folder with FileExplorer (Windowsexplorer) and start QCAD with a double click on qcad.exe
if it works, create a shortcut to qcad.exe for a more convenient use.
Certina: Please install the Microsoft "Update for Universal C Runtime in Windows":
https://support.microsoft.com/en-us/top ... 7930f3560c
Please let me know if this does or does not fix the issue.
Thank you.
I downloaded the indicated file, that is: Windows6.1-KB2999226-x86
I got the message: this update does not apply to this computer.
Thanks.
Please install the "Visual C++ Redistributable for Visual Studio 2015":
https://www.microsoft.com/en-in/downloa ... x?id=48145
Installation failed: 0x80240017 - unspecified error.andrew wrote: ↑Mon Aug 22, 2022 2:43 pmThanks.
Thanks. Unfortunately, I don't think QCAD can install or run on your system. Frankly, I think your Windows installation is fundamentally broken and should be set up from scratch.
Thank you very much for your good intentions.
System Restore didn't help either.
I will have to reinstall the system.
Regards Certina
Regards Certina
Fixed.
It was enough to install the update: KB2999226
