Parallel Selection
GizFab
Parallel Selection
Post by GizFab » Thu Jul 21, 2022 10:09 am
Morning, Is it possible to use the Parallels tool to create a Parallel around an entire selection without having to click each node/ spline separately?
For example some Text? Could i select the letter "A" and be able to one-click a 3mm Border/ Parallel around the letter?
I hope this makes sense.
Re: Parallel Selection
Post by andrew » Thu Jul 21, 2022 1:59 pm
Yes:
https://qcad.org/doc/qcad/latest/refere ... /OffsetPro
Text would have to be exploded first into polylines:
https://qcad.org/doc/qcad/latest/refere ... oc/Explode
For efficient support, please note the forum rules above in red.
