Screen based linetype as default
wendi
Post by wendi » Fri Jul 08, 2022 6:22 pm
Win 10Pro64; Qcad 3.27.6. Is there a way to have my activation of "screen based linetype" stick between uses? I have to manually change it from draft mode every time I launch. Thank you.
J-J
Moderator
Re: Screen based linetype as default
Post by J-J » Fri Jul 08, 2022 6:56 pm
Hi
May-be that is what you need:
check auto switch, I have it on permanently.
JJ Win7 pro-64
wendi
Post by wendi » Fri Jul 08, 2022 7:17 pm
That did it! Thank you.
