Isometric
ross
Isometric
Post by ross » Tue Jun 28, 2022 6:12 am
Hi
Mac--Monterey-12.4 Qcad pro 3.26.2
Can I get an isometric drawing from an existing 2 d drawing without having to draw the whole item in isometric.
Ross
Re: Isometric
Post by Husky » Tue Jun 28, 2022 8:00 am
Yes, QCAD can help you to project each face of an existing drawing into an isometry. But it isn't a full automatic projection - QCAD needs still your help ... :wink:
To get a feeling for the tool select a face like a frontview and launch the isometry tool below Menu / Modify / Projection / Isometry Projection. Keep an eye on the option bar - I assume it is intuitive ...
ross
Re: Isometric
Post by ross » Tue Jun 28, 2022 11:02 am
Hi--Thanks----very clever.
Maybe asking a lot now--can I give it a thickness to make it 3d or does this need to be drawn in as an addition.
Thanks again--Ross
Re: Isometric
Post by Husky » Tue Jun 28, 2022 5:59 pm
... can I give it a thickness to make it 3d or does this need to be drawn in as an addition.
No, QCAD is a 2D program. To do some 3D work you need a 3D program ...
ross
Re: Isometric
Post by ross » Wed Jun 29, 2022 4:36 am
Hi --------- Thanks
