[solved] assembly drawing
ross
Post by ross » Mon Jun 27, 2022 12:28 pm
Hi-- Mac OS Monterey. Qcad pro 3.26.2
When making an assembly drawing ----- by dragging individual drawings of parts into the assembly drawing--Can I make each part a different colour--I have tried with new layers but with no success.
Ross
Re: assembly drawing
Post by andrew » Mon Jun 27, 2022 2:39 pm
Putting the inserted drawings on separate layers seems like the best way to go.
Note that if you drag drawing files into your drawing area, a block is created in the process. Changing the layer of the resulting block reference will not change the layer of the entities in the block. To do that, you'd have to edit the block (double click on it), select all and change the layer in the property editor, then Block > Return to Main Drawing.
If you attach your drawing, we can help more efficiently.
ross
Post by ross » Tue Jun 28, 2022 6:01 am
Hi Andrew
Works for me--thanks--Ross
